I need some help from you gays.
I download the file of the installation from the web here (ardupilot.com/downloads/?did=90)
After the driver installation I copy the App Apm Planer to application folder.
the problem start here after that I open the Apm planer!
in the right side on the top there are two small windows where I’m supposed to set the port speed and port type-COM.
But unfortunately the software shows me only two options:
bluetooth-incoming-port
bluetooth-modem !!! I attached photo !!! http://postimg.org/image/tkhe4kb1f/
I know that I need to see some more options like COM or USB
thanks to all helpful
Yes I know that I need to see this but in my Mac its not show!
In my pc(windows) its work good without any problem.
The driver is instal good I test it again.
Can you have please other Solution?
The problem is that I don’t know why it’s not working for you guys. If you have installed the the FTDI drivers, you should be able to see the Telemetry Radios.
Without installing any drivers you should be able to connect to PX4 and as it’s supported built in.
Yes I running the last ver of APM 2.0.10
and I also instal the driver FTDI but its dont working at all!
I know some people that have the same problem on Mac with osx 10.9.3
I think its something in Mac preference but I dont know what…
I am running Mavericks on both an older iMac and a Macbook air. I can have that problem if I plug in the module AFTER I start up APM P. Perhaps your issue is more involved than that but might want to try and shut down APM P… remove and then plug in again the module… relaunch APM P and see if it’s in the list.
same problem here. I run APM Planner on a MBP with the latest OS X 10.9.3 and the latest APM Planner v2.0.10. I have the same issue like some writers above. I Only see the bluetooth connections.
I tryed to connect to my pixhawk from an old and a new MacBook pro.
We did some major rework on the serial port handling to improve the stability. This new daily release fixes that. And it will be in the next 2.0.11 release.
