I have a problem with using the MMC34160PJ compass module. I’m runnig the module from 5V and it has a 3.3V LDO on the board. The I2C Bus runs also on 3.3V and the I2C lines have 4.7k pullup resistors. With an arduino the board seems to be recognized (it responses with the correct bus adress). But connected to the Cube it’s not recognized at all.
Does anyone have any expierence with this compass? In the documation it says that the module is supported and from what I’m seeing in the code it should work as well. I’m out of ideas at that point.
- Chris
