Hello
I am unable to set up the development environment, when I try to run
python setup.py build install --user
I get the following error:
Traceback (most recent call last):
File "setup.py", line 1, in <module>
from setuptools import setup
ImportError: No module named setuptools
From googling around i stumbled upon this issue on github which I think might be of relevance, but I am not sure as i am brand new to the setup and workflow of MAVProxy. Is this the problem and how do i fix this?
Edit: I am using an NVIDIA Jetson Orin Nano with Ubuntu 20.04.6 LTS
Right, it should already be installed. I tried to install it with pip again and get this message:
Requirement already satisfied: setuptools in /usr/local/lib/python3.8/dist-packages (72.1.0)
Maybe i could get someone to check whether setuptools is located in the right directory?
I have also tried to add the location of setuptools to PYTHONPATH (even though i assume it would have been mentioned in the guide if this was neccesary)
