we have a problem with 2 drones using the RM3100 Compass with latest DEV Firmware.
We use on both the orange cube and because of the parameter reset problem, we use the latest DEV Firmware
The RM3100 gets not detected as such,
With the 4.03 Firmware, it does
When we try to calibrate the compass, we get after a while always the error message
Mag(0) bad radius 6xx expected 4xx
Is there something we are missing? Here is also our parameters
Profile Orange.param (18.2 KB)
4. With the 4.03 Firmware, the calibration does work fine.
Hope someone can have a look at the parameters.
I know something new was introduced in 4-dev:
ArduPilot:master
← tridge:pr-rm3100-scale
opened 07:21AM - 26 Mar 20 UTC
maybe has something to do with it. Tridge merged a bit “controversial” fix. Since, supposedly, it fixes a calibration issue, maybe is related.
Thank you for the information, I think this is related.
@tridge
I checked the compass scale on another drone with black cube and rm3100, it was 1.009884. And worked fine for the last 2-3 month.
Anything we are doing wrong on the new Dev firmware?
tridge
(tridge)
May 15, 2020, 7:46am
4
I’ve opened a PR against MissionPlanner to fix this:
ArduPilot:master
← tridge:pr-rm3100-id
opened 07:44AM - 15 May 20 UTC
old one is deprecated due to ID change to cope with incorrect scale
factor
that is strange. Can you post a LOG_DISABLED=1 onboard log showing the calibration failing?
Hi @tridge thx for the feedback, you can find the log here
