If you have problems reading log on microsd card here is the solution
format your microsd with SD Card Formatter and turn is play
I too am a windows user, and I have found that if I make sure to format the card in FAT32 it works fine, The default is probably NTFS.Also make sure you do NOT do the quick format. It will take much longer but will do a real format.
