I have problem with Mauch HS-100-HV with battery 6s on Cube Black. I calibrate it with info from doc ( V divider 19,03498, A/V 31,17486). Voltage meter is ok, on standby 22,6v but current ampers still 0. When I run motors with my meter (9ampers) in mission planner still 0… and my log from flight
Are you sure, it is wired on the right direction ? There are arrows on the sensor which indicates current flow direction. (Tail of the arrow : Battery)
Hello! Maybe is obvious but have you checked that the Mauch is wired correctly? It has little arrows that show you the direction of the current. If it is inversed, then you have that noise.
