Hi all,
I’m trying to setup APM2.8 with companion computer RPi model A.
I made it work using the mavproxy. The additional parameter was needed to specify the old protocol:
Next step is I’m trying to run the mavlink example program https://github.com/mavlink/c_uart_interface_example. Unfortunately the example is not working. Looks like that the initial steps work, but the current position cannot be read and the program stuck:
I tried couple of different things like building the example code from older commit with the older version of the mavlink c lib for 1.0. Also I tried to replace the
#include <common/mavlink.h>
with:
#include <ardupilotmega/mavlink.h>
Unfortunately non of this works.
The behavior is very similar to mavproxy without the --mav10 switch:
My question is how to make the mavlink lib work against the APM? What is the equivalent of --mav10 in mavproxy against the c API? I would expect that just including ardupilotmega/mavlink.h should be enough, but seems not.
Thanks in advance,
Ivan Stoyanov
