Hi guys, let say i’m forget to disable Battery FS when i flown indoor
and then when in a mid of flight then battery FS get triggered
is the quad would be climb (doing RTH) even there is no GPS LOCK at that time (because i play indoor) or what would the quad behave with that FS?
But this is still a good question. I can’t find in documentation what will be the behavior in that case.
Will it just stay in current fly mode or land?
From my experience I can tell that it landed 9 of 10 times. As I didn’t know better.
10th time it crashed into the ceiling.
I’m not quite sure if it got GPS lock by accident indoors, or what happened, but I changed settings for just land.
BTW not directly related to the topic question but I thought - what will happen if you’re in RTL mode (copter flying home) and GPS signal lost?
Will that casue a fly-away?
I think your test was not representive, as your copter didn’t leave the launch position. Where should it return to?
I think I read somewhere that it will anyway just land if it is not out of ?5m? radius from launch.
I’m about that it could be a safety issue in the firmware. If a copter cannot return because of bad positioning then it is better to land instead of fly-away.
