111186
(Daisuke Ide)
February 18, 2020, 10:23pm
1
The Following Message is printed by the PreArm check:
2020/02/19 7:19:20 : PreArm: UC: Duplicate Node com.hex.here…/20!
What does this mean?
2020/02/19 7:19:20 : PreArm: Compass not calibrated
2020/02/19 7:19:20 : PreArm: Throttle below Failsafe
2020/02/19 7:19:08 : EKF2 IMU0 tilt alignment complete
2020/02/19 7:19:08 : EKF2 IMU1 tilt alignment complete
2020/02/19 7:19:07 : EKF2 IMU1 initial yaw alignment complete
2020/02/19 7:19:07 : EKF2 IMU0 initial yaw alignment complete
2020/02/19 7:19:05 : GPS 1: specified as UAVCAN
2020/02/19 7:19:04 : Frame: QUAD
2020/02/19 7:19:04 : CubeYellow 002F002D 3238510D 38323430
2020/02/19 7:19:04 : ChibiOS: cb42c858
2020/02/19 7:19:04 : ArduCopter V4.0.2 (aae944a8)
2020/02/19 7:19:04 : Initialising APM
2020/02/19 7:18:59 : Initialising APM
2020/02/19 7:18:58 : Barometer 3 calibration complete
2020/02/19 7:18:58 : Barometer 2 calibration complete
2020/02/19 7:18:58 : Barometer 1 calibration complete
iampete
(Peter Hall)
February 18, 2020, 10:37pm
2
you have to here2’s plugged into the same CAN port? You need to change the node id of one of them (you can do this via the slcan params). Or put the second one on the other can bus and driver
111186
(Daisuke Ide)
February 18, 2020, 10:51pm
3
Thank you for the appropriate advice.
I have only one Here2 connected to CAN port 1. There are no other devices with CAN. When the CAN ID of Here2 was changed to 21, the error was no longer displayed. Is ID20 something used internally?
iampete
(Peter Hall)
February 18, 2020, 10:55pm
4
ArduPilots Default ID is 10, Odd that you had a conflict I guess you didn’t change it? (CAN_D1_UC_NODE)
111186
(Daisuke Ide)
February 18, 2020, 11:28pm
5
iampete:
CAN
I checked the CAN_D1_UC_NODE. It was the default 10. In this state I tried to return the ID of Here2 to 20 for reconfirmation, but still see the same error.
I’m testing this with YellowCube now. I’ve also tested Black and Orange, but that doesn’t happen.
iampete
(Peter Hall)
February 18, 2020, 11:59pm
6
Odd, can you turn on LOG_DISARMED and upload a log of the issue, maybe one of the CAN experts knows whats going on, @rmackay9 @tridge
111186
(Daisuke Ide)
February 19, 2020, 12:28am
7
Link of log.
The yellow cube is mounted on the Kore Carrier Board for testing. Here2 is connected to CAN1.
Did you ever find a fix for this issue? im using a black cube with only one here2 GPS.
Having Same issue with Here2 GPS and other UAVCAN devices.
mainframe
(Andres Toomsalu)
June 19, 2022, 9:50pm
10
Could be related to persistent UAVCAN device hw id/uavcan id map:
opened 08:25AM - 01 Oct 20 UTC
CAN
## Bug report
**Issue details**
The map of node's unique hardware id to UA… VCAN node id is stored in persistent storage. So when connecting a different device with the same node id (after disconnecting the first device and rebooting AP of course) it will report it as duplicate id.
How to recreate the bug:
Connect a UAVCAN device with a static node id. Then reboot AP and connect a different device (with a different hw id) with the same static node id.
**Version**
Copter-4.0.4
**Platform**
[ ] All
[ ] AntennaTracker
[X] Copter
[ ] Plane
[ ] Rover
[ ] Submarine
**Airframe type**
hex
**Hardware type**
mRoControlZeroF7
