I’m setting up a rover and everything works fine until I try to arm it when I get that error. I’ve checked the SD card and formatted it with my computes and it’s working fine, so it is not a problem of the card. The only solution that I found is bypassing the logging check with the ARMING_CHECK parameter and it works correctly, it logs both on the SD card and via MavLink. So, anyone knows why this may be happening?
