I have HDOP at 1.07
GPS FIX: 4.0
GPS sats: 9
Arming gives prearm: gps speed error 1.0
I had to wait a long time (minutes) before getting
HDOP 0.86
Fix: 4.0
Sats: 11
and finally I was able to arm
Strangely if I power cycle, the next time it just arms without problems with HDOP 1.32.
Is the pre-arm being a bit too sensitive here? If I get this too often, do I need to turn off GPS altogether from pre-arm checks, or is there a better way?
I’m using the 3DR GPS with a pixhawk on a plane where the GPS is nowhere close anything else except the 2 cables going to it.
Sadly, this also crashes apmplanner 2.0.19-rc4. Is there a mailing list or proper location to report apmplanner crashes?
DEBUG 2015-10-30T08:54:46.593 APM: Text Message rx’d "PreArm: GPS horiz error 5.4"
INFO 2015-10-30T08:54:46.593 “/home/merlin/apmplanner2/tmp_audio/Pre-arm_check:_GPS_horiz_error_5.4.wav” file not exist, create a new one
VAL: tried to access cart in -1 type val
[1]+ Exit 255 apmplanner2
DEBUG 2015-10-30T08:58:00.927 APM: Text Message rx’d "PreArm: GPS speed error 1.5"
INFO 2015-10-30T08:58:00.928 “/home/merlin/apmplanner2/tmp_audio/Pre-arm_check:_GPS_speed_error_1.5.wav” file not exist, create a new one
[1]+ Segmentation fault (core dumped) apmplanner2
For now, I’m using ARM_CHECK 2030 to turn off this check that keeps failing without good reason I can find and things seem to be ok in flight.
I’d love to know more or help find why this isn’t working as it should.
Those messages are coming from the EKF when the GPS velocity, acceleration and not consistent with the IMU (gyros + accels). That could either be because the data from the GPS isn’t good at the time, or maybe because of a bad accel or gyro cal. I actually suspect it’s just the GPS. The reason that it was fine even when rebooted is because the GPS has a battery in it, so that even if it’s rebooted it doesn’t look all the information it’s gathered.
Howdy. I just now had the time to do a full gyro/compass recal in mission planner.
Same exact thing:
PreArm: GPS horiz error 9.3
PreArm: GPS horiz error 11.9
PreArm: GPS horiz error 5.7
I’ve put pream checks back to 2030, and I can arm again.
GPS HDOP is 1.31
I have a genuine pixhawk and a genuine 3DR compass module.
If we’re pretty sure it’s not a firmware issue, what can be causing this?
my pixhawk was armed in stabilize or althold modes in an open place but was not armed in poshold or loiter or RTL mode and I get error message : GPS Speed error 1.0
my frameware version is copter 3.5.5 .I dont know what’s that reason?
