hi! I’m running ArduPlane 4.3.2 on a Matek H765-WLITE, and am getting a strange prearm error. it says “battery 1 unhealthy” but i can get a readout of the battery voltage and current, and there all calibrated, so i have know idea what could be causing it.
heres all my BATT* config perams:
BATT_AMP_OFFSET,0
BATT_AMP_PERVLT,66.7
BATT_ARM_MAH,0
BATT_ARM_VOLT,0
BATT_CAPACITY,2200
BATT_CRT_MAH,0
BATT_CRT_VOLT,0
BATT_CURR_PIN,11
BATT_FS_CRT_ACT,0
BATT_FS_LOW_ACT,0
BATT_FS_VOLTSRC,0
BATT_LOW_MAH,0
BATT_LOW_TIMER,10
BATT_LOW_VOLT,10.83
BATT_MONITOR,4
BATT_OPTIONS,0
BATT_SERIAL_NUM,-1
BATT_VLT_OFFSET,0
BATT_VOLT_MULT,21
BATT_VOLT_PIN,6
BATT_WATT_MAX,0
BATT2_MONITOR,0
BATT3_MONITOR,0
BATT4_MONITOR,0
BATT5_MONITOR,0
BATT6_MONITOR,0
BATT7_MONITOR,0
BATT8_MONITOR,0
BATT9_MONITOR,0
like i said, battery voltage and current readouts are OK, but the battery level readout is blank.
any help appreciated
