Pre-flight: battery level in red?
I use Mission Planner 1.3.48. In pre-flight window the check list battery level is always in red.
I use a 3s, 4s or 6s for hexacopter, and the battery failsafe is 10,6v. Battery level in pre-flight is > that the battery failsafe voltage.
Can you help me please, what is the failure?
and, it’s possible to indicate the cells number of the lipo?
thanks a lot
David D
you can edit the value that it uses to turn from green to red, just click edit, and change the number
David,
Under ConfigTuning, Standard Params, Battery Current Sensing Pin, Battery Monitoring,and Battery Voltage Sensing Pin, have you configured the flight controller your are using?
Randy
