Pre-arm: GPS2 not healthy
I have an issue with arming a VTOL plane using two HERE3+ GPS. No matter what settings regarding GPS I set the message " PRE ARM: GPS2: NOT HEALTHY". Both of the GPSs have 15+ satellites and HDOP is below 1. I tried increasing GPS_RATE_MS for both GPSs but there was no change. When using only one GPS no matter which one there is no error with GPS signal being unhealthy. I need to use two however. I’ve uploaded an example log file: https://drive.google.com/file/d/1TUVphQtfbAE_LRDMEXnqNe5ao4DEZ5jh/view?usp=sharing
I am using the latest ArduPlane 4.3.3
