I want to use the PPM encoder v3 with my Spektrum AR6210 which has an additional satellite. RC: DX6i. However, if I connect the receiver (with satellite attached) to the PPM encoder and connect it to my pixhawk (2.4) and do a RC calibration (using MP) I get the following (strange) values:
Ch1: 1600-2007 (Roll)
Ch2: 1000-1403 (Pitch)
Ch3: 991-1412 (Throttle)
Ch4: 1600-2006 (Yaw)
Ch5: 991-1413 (Switch 1)
Ch6: 1592-2014 (Switch 2)
In consequence, I always get a “prearm: RC calibration” error and cannot arm the device. In addition (if I disable this check) the motors control does not work properly, i.e., only 2 motors are spinning, even at full throttle.
If I connect the satellite directly to the pixhawk, everything is fine (calibration as well as motors). However, I want to use the main receiver for increased range.
Here are the calibration values for satellite only:
Ch1: 1161-1945 (Roll)
Ch2: 1164-1937 (Pitch)
Ch3: 1061-1867 (Throttle)
Ch4: 1162-1944 (Yaw)
Ch5: 1061-1867 (Switch 1)
Ch6: 1151-1957 (Switch 2)
Any ideas what is wrong and how to fix this?
Thank you!
