The cube comes with a mini power brick 30amp, is there any reason with the older version pixhawk 90amp power module wouldn’t be ok to use on the cube
You can use it. Just make sure pinouts are correctly matched and power module is trust worthy.
Ok great, are the connectors different on the old and the new if so can they be removed and are there pinout charts available that show the connection
