Hi! I’m develop drone which is controlled by raspberry pi 5. Question is, how to power raspberry and drone from single battery? I’m using matek h743 flight controller, but it have 5V2A bec (3A max) which I think is not enough to provide stable power for raspberry pi.
My idea is to buy xt60 Y splitter and one side is connected to drone, and another is to dc-dc step down converter, which will give 5V 5A to raspberry. Is that good idea? Or there can be more better solutions.
Thanks!
You can get 5.2V BEC which are more suitable to Raspberry Pi3B+ and up.
You can buy a dedicated power supply like the Pi-Connect Lite (https://www.robotshop.com/products/rpanion-pi-connect-lite-v2). It also has telemetry ports for connecting to the flight controller.
Thanks! I’m going to use matek 12s pro bec. I’ve got yesterday one more suggestion, solder wires to drone esc ( where drone power wires soldered) and then solder this wires to BEC input. Is somebody tried similar solution? ESC is speedy bee 4 in 1
@sashacomn did you manage to figure this one out?
I stumbled upon this thread because I had the same thoughts as you, and I saw two options:
- a Y-splitter for XT60 and then a step down converter like this one
- use the 5V pad on a flight controller (although here, I’m worried the required current might damage the flight controller)
But then I found opinions online that it’s very important for the power source to be VERY stable, and I’m not sure this is the case for either of the two solutions.
Any additional thoughts on your side?
Alternatively, you can consider such a module.
DC 9V-35V 65W Full Protocol Mobile Phone Fast Charging Module Type-C+USB Support PD3.0/PPS/QC2.0/3.0/4.0AFC/FCP/SCP
We have tested it is okay to use.
Thanks, @Jai.GAY, that module looks even better as it doesn’t have the display and is hence lighter!
And you tested that with RPi 5 or RPi 4? Just to be 101% sure
We tested on RPi5. Hope it is helpful to you.
Yes, very much so, thank you!
