This is a renewed high-quality power module standard based on the ACSP7 but with dual internal power supply to improve the stability of the hall-sensing.
The mRo Power Zero from mRobotics is designed especially for the Ardupilot community and it offers extremely accurate measurements across the entire current & voltage operating range with a non-invasive Hall-effect current sensor for UAV / Robotics application and high precision voltage dividing circuit for consistent and reliable measurements.
Compared to the ACSP7, the .5v offset is removed and the current sensing is compared with a dedicated power reference. The integrated electrolytic capacitor reduces voltage spikes which result from longer input cable lengths and higher voltage batteries.
If you want to make your own cables and route them to connect it to your autopilot, you can simply follow the order of the pinouts as it is the same Dronecode standard.
Very nice and an option to add the following accessories might make it more attractive to some of us like:
XT90 plug also
FC cable in two different sizes (or more)
Enclosure
Hello, wouldn’t it be better to have a vendor dedicated section and leave the blog to interesting tech project stuff?
Probably hardware vendor section should be described as “support and marketing” so that all commercial stuff goes in there and doesn’t infest blog
