Hi all,
Does anyone have a good power module schematic to share ?
Warmly !
Hi all,
Warmly !
Depending on which switch mode controller you go for, the datasheet will contain “typical application” schematic, which would usually require very little tweaking to be optimal for your use.
So start by selecting an controller with suitable voltage and current/power rating
I’m looking for a common ACS758ECB hall sensor (100A or 200A depending on drone power)
The goal is to integrate it directly on a power board to save space and get a clean drone setup. I already made and integrated a 5V regulator (up to 6S) to power the pixhawk.
If someone got this to share, it could help to save time
Don’t forget that pixhawk needs 5.4V for power not 5.0V
