What type of connector is this? Is it possible to buy just the power supply cable?
I’m upgrading a multirotor with a Nora. It came with the CAN power supply but I plan on using the Mauch that is already installed.
I can cut up the cable that came with the CAN power supply, it fits in the ADC power supply input, but was curious about getting a connector to build a new cable.
You can buy just the cable through their aliexpress store front, but it doesnt say exactly what connector type it is
Thanks! It’s not very clear what exactly you’re ordering from that site but we’ll see what I get.
Usually theres some buttons for different options, like ONLY the cable.
Hi @xfacta the link you provided doesn’t exist,i want to buy this CUAV X7+ Power cable with connector to use it with seperate module.
I couldnt find the cable easily by searching.
Search for the official CUAV store on aliexpress
“aliexpress Store No.3257035”
then select cable from the product list
or try this link direct to the cable
https://www.aliexpress.com/item/1005003089677561.html?spm=a2g0o.store_pc_groupList.8148356.1.4de36d42IUNAbR&pdp_npi=3%40dis!AUD!AU%20%244.81!AU%20%244.81!!!!!%40211b88ec16934655363682495ecf24!12000024019831610!sh!AU!0
I just ran into this same issue, trying to find a cable to go between the Mauch HYB-BEC and the CUAV Nora+ Power A. Here is my Digikey and Amazon BOMs for building the cable:
DigiKey:
MPN____________Description_______________________
1511000006______Molex 6pos 2.00mm housing
0503948051______24-30 AWG crimp Gold
5023800600______Molex 6pos 1.25mm (Clik-Mate) housing
5023810010______26-28 AWG crimp Gold (For Clik-Mate)
Amazon:
26 AWG wire
iCrimp tool or Ratchet Crimp tool
I did just order this, so I haven’t proven this build yet. But these should be correct.
The less-common connectors used on the CUAV X5, X7 carrier boards and Nora power inputs are Molex 2.00mm Pitch Milli-Grid.
This matches what Derek said above, I just wanted to put this here as confirmation since I was checking around for sources too.
4 pin locking CAN connector is
DigiKey part number 1511000004-ND
Molex part no. 1511000004
6 pin locking power connector is
DigiKey part number WM26843-ND
Molex part no. 1511000006
Crimp connectors
DigiKey part number WM1128CT-ND
Molex part no. 0503948051
