Can someone tell me the exact maximum continuous current that power brick mini can withstand?
The websites show that it is 30A continuous but people say that it can be operated at much higher current.
If anyone knows then please let me know.
Hi zabbie,
Did you got an answer for this question or figured it out yourself? I’m also thinking about the use of provided Cube power brick mini or changing it to another type of power module with higher current rating.
Thanks,
Janos
i confirmed with the company the brick mini that comes with pixhawk cube has the ability to stand continuous current of 30Amps only. So, I would recommend you to use Mauch power module if your system consumes more current than that.
Hi, is there a way to tell if a quad will use more than 30amps continuous power , I have a s500 quad with 30 amp esc, with pixhawk 1 on it , would the power module I use on it work on a pixhawk cube without issues
Thanks
