I’m currently having a APM2.6 and is required to use a servo for my camera and I have read the Ardupilot website regarding having a servo requires the 5V and GND to be connected to the Output rail instead of the A(10/11) to prevent noise /brownout when there movement in the servo.
I look through the connection from the APM hardware page regarding the power distribution but I do not have a clear picture as there are no picture to illustrate the words. So I have drawn a figure for the connection.
Can any one tell me if I have gotten the connection right? The links shows my connection
You diagram is exactly correct except for one thing. The Power Module connects only to its input on the APM. You show a yellow arrow going to the left from the Power Module. This is not correct. But the way to are providing power to the output rail is right.
I thought that might be the case but didn’t want to assume that’s what the OP meant. He draws it as a direct connection, which it isn’t. And also by drawing it the way he did implies the PM is somehow feeding power to the output rail BEC, which it doesn’t.
