we want to use 2 BLHeli_32 ESCs and 2 other esc.
It would be great to drive the BL_heli ones with Dshot (and telemetry on separate cable, BDshot is a bit too much to start with) while having the other 2 esc on conventional PWM.
I only found MOT_PWM_TYPE that probably changes all motors.
Is there another way? Or an easy fix in the source code for this? (We compile ourselves anyways)
I already know that the Dshot pins have to be in one separate Pin-group, that would be possible.
You should be able to set MOT_PWM_TYPE to 0 (see PWM, OneShot and OneShot125 ESCs β Plane documentation for tuning the PWM ESC parameters), then set SERVO_BLH_MASK to your two BLHeli_32 ESCs, then set SERVO_BLH_OTYPE to the appropriate Dshot speed for those two.
On Plane, all other motors use Normal (PWM) protocol. However, in Plane, any motor, like the traditional fixed wingβs main motor or Dual Motor Tailsitters (SERVOx_FUNCTION = 70 throttle, 73 throttle left and / or 74 throttle right), can be changed to a protocol other than PWM using the SERVO_BLH_MASK parameter to specify the output number of the motor together with the SERVO_BLH_OTYPE parameter to select the protocol of these motors independently of that selected for the copter function motors.
Servo_blh_mask seems to be perfect. No idea how i missed that. But i mainly looked in the Dshot section not in the standard output documentation. Iβm currently building up a small teststand. I will then test this and report back.
