Hello, a few days ago, I tried installing Ardupilot to a Parrot Disco. This was one of a pair of identical Discos, bought years ago from the same place. I had originally installed Ardupilot (no idea which version, whatever was around at the time) following the instructions of this video. The take home message from the video was that I did not transfer the rcS_mode_default file but only the arduplane binary and start_ardupilot.sh. This had worked great the first time I tried and I could switch between the originan Parrot firmware and Arduplane by triple clicking the button, as opposed to immediately booting into Arduplane.
Now, I tried the same but, after triple clicking the button, the LED flashed red (indicating possible loading of Ardpuplane) but neither Mission Planner nor QGroundControl would connect to the vehicle. I got wireshark to listen to my wifi interface and, as far as I could tell, no incoming UDP packets were detected.
To dig a little deeper, I connected to the Disco over telnet and manually fed the terminal the commands of start_ardupilot.sh. Here are the outputs:
/data/ftp/internal_000 # cd /data/ftp/internal_000/ardupilot
/data/ftp/internal_000/ardupilot # /bin/date
Thu Jan 1 00:06:03 UTC 1970
/data/ftp/internal_000/ardupilot # /bin/ls
arduplane start_ardupilot.sh
/data/ftp/internal_000/ardupilot # /bin/dragon_ipc.sh dragon_shutdown
POMPCLI: event_cb : event=0(CONNECTED) conn=0x284918 msg=(nil)
POMPCLI: event_cb : event=1(DISCONNECTED) conn=0x284918 msg=(nil)
/data/ftp/internal_000/ardupilot # /usr/bin/killall -KILL dragon-prog
killall: dragon-prog: no process killed
/data/ftp/internal_000/ardupilot # /usr/bin/pstop ledd
/data/ftp/internal_000/ardupilot # echo 1 > /sys/devices/platform/user_gpio/FAN/
value
/data/ftp/internal_000/ardupilot # echo 1 > /sys/devices/platform/user_gpio/RESE
T_GNSS/value
/data/ftp/internal_000/ardupilot # echo 0 > /sys/devices/platform/user_gpio/RESE
T_GNSS/value
/data/ftp/internal_000/ardupilot # echo “$(date) Starting arduplane”
Thu Jan 1 00:07:51 UTC 1970 Starting arduplane
/data/ftp/internal_000/ardupilot # ./arduplane -A udp:192.168.42.255:14550:bcast
-B /dev/ttyPA1 -C udp:192.168.43.255:14550:bcast --module-directory modules
./arduplane: /lib/libm.so.6: versionGLIBC_2.27' not found (required by ./arduplane) /data/ftp/internal_000/ardupilot # ./arduplane: /lib/libm.so.6: version
GLIBC_2
.27’ not found (required by ./arduplane)
It appears the arduplane binary is choking on libm.so.6
I checked for the filename and it exists but I have no idea how to examine its version:
/lib # ls /lib/libm*
/lib/libm-2.19-2014.08-1-git.so /lib/libmount.so.1
/lib/libm.so.6 /lib/libmount.so.1.1.0
/lib/libmount.so
Does Plane 3.9 need a more recent version than whatever is in the original CHUCK installation? If so, any idea how to install it?
Edit to add that the firmware version in the Disco is 1.7.1, which is up-to-date as of today (link to Parrot Disco support) so no joy by trying to update via that channel.
