I’m trying to connect an ardupilot SITL setup to QGroundControl (but this problem is pretty generic to any ground station). I can run this on the host machine:
cd ArduCoputer
sim_vehicle.py -w
SIM_VEHICLE: "mavproxy.py" "--master" "tcp:127.0.0.1:5760" "--sitl" "127.0.0.1:5501" "--out" "127.0.0.1:14550" "--out" "127.0.0.1:14551"
and QGC connects instantly (on UDP 14550). I can see packets being sent with sudo tcpdump -i lo -n udp port 14550
without the ground station connected.
I’ve now set this up to run in Docker, and I can get sim_vehicle
running, but I’m struggling to figure out the port settings.
For example, if I run docker run -it -p 14550:14550/udp ardupilot
(with an entrypoint to sim vehicle), SITL starts. If I try and connect, QGS complains:
"UDP Link Error" "Error binding UDP port: The bound address is already in use"
Similar error using pymavlink
. I also can’t see any traffic using tcpdump.
I tested with a jupyter notebook server to check that I could port forward something (eg -p 8888:8888
So I’m guessing this is something to do with how I’m forwarding UDP, but no idea why I’m not getting any traffic out. I’m running Kubuntu 19.04. Any advice is much appreciated, thanks!
This is the container, FYI:
FROM ubuntu:16.04
WORKDIR /ardupilot
RUN useradd -U -d /ardupilot ardupilot && \
usermod -G users ardupilot
ENV USER=ardupilot
RUN DEBIAN_FRONTEND=noninteractive apt-get update && apt-get install --no-install-recommends -y \
lsb-release \
sudo \
software-properties-common \
git \
python-software-properties && \
apt-get clean && rm -rf /var/lib/apt/lists/* /tmp/* /var/tmp/*
# Passwordless sudo for ardupilot user
RUN echo "ardupilot ALL=(ALL) NOPASSWD:ALL" > /etc/sudoers.d/ardupilot \
&& chmod 0440 /etc/sudoers.d/ardupilot
RUN git clone https://github.com/ArduPilot/ardupilot $(pwd)
RUN cd /ardupilot && git submodule update --init --recursive
RUN chown -R ardupilot:ardupilot /ardupilot
# Assumes fixed install script
RUN bash -c "Tools/environment_install/install-prereqs-ubuntu.sh -y && apt-get install gcc-arm-none-eabi -y" && \
USER ardupilot
ENV CCACHE_MAXSIZE=1G
ENV PATH /usr/lib/ccache:/ardupilot/Tools:${PATH}
ENV PATH /usr/lib/ccache:/ardupilot/Tools/autotest:${PATH}
ENV PATH /ardupilot/.local/bin:$PATH
# Build SITL/Copter
RUN ./waf configure --board sitl
RUN ./waf -j8 copter
EXPOSE 14550/udp
EXPOSE 14551/udp
EXPOSE 5760
ENTRYPOINT cd /ardupilot/ArduCopter && sim_vehicle.py -w --no-rebuild --console
