This is working in guided mode only ,can you make it work in loiter also please
I to would like to be able to “point camera here” and then manually fly around with a 3 axis gimbal.ether by using a ground station or better still manually point the camera at a ROI then record and hold that position with a switch on the Tx . and assume that the ROI is ground level
