I recently saw this repo GitHub - ArduPilot/plotjuggler-apbin-plugins: ArduPilot Dataflash plugin for Plotjuggler which is a plugin for Plotjuggler. Plotjuggler seems to be widely used in the robotics community and since I do not have much experience with it I was wondering if this is still a good choice or whether UAV Log Viewer is considered the standard tool now?
Perhaps a dumb question but I am facing the following installation issue, and having zero cmake experience makes it difficult to debug it.
CMake Error at CMakeLists.txt:66 (find_package):
By not providing "Findplotjuggler.cmake" in CMAKE_MODULE_PATH this project
has asked CMake to find a package configuration file provided by
"plotjuggler", but CMake did not find one.
Could not find a package configuration file provided by "plotjuggler" with
any of the following names:
plotjugglerConfig.cmake
plotjuggler-config.cmake
Add the installation prefix of "plotjuggler" to CMAKE_PREFIX_PATH or set
"plotjuggler_DIR" to a directory containing one of the above files. If
"plotjuggler" provides a separate development package or SDK, be sure it
has been installed.
Yes, that solved (partially) the problem. Now I am facing this:
CMake Error at /home/ntouev/plotjuggler_ws/build/PlotJuggler/plotjugglerConfig.cmake:31 (include):
include could not find requested file:
/home/ntouev/plotjuggler_ws/build/PlotJuggler/plotjugglerTargets.cmake
Call Stack (most recent call first):
-- PlotJuggler FOUND
-- plotjuggler_INCLUDE_DIR: /home/ntouev/plotjuggler_ws/install/include
-- plotjuggler_LIBRARIES: plotjuggler_base
-- Configuring incomplete, errors occurred!
See also "/home/ntouev/plotjuggler-apbin-plugins/build/CMakeFiles/CMakeOutput.log".
I checked and /home/ntouev/plotjuggler_ws/build/PlotJuggler/plotjugglerTargets.cmake is indeed not present. I followed these instructions for installing plotjuggler.
git clone --recurse-submodules https://github.com/facontidavide/PlotJuggler.git
cd PlotJuggler
mkdir build; cd build
cmake ..
make -j
sudo make install
cmake --build build/PlotJuggler --config RelWithDebInfo --target install
^ That installs it in a local directory. The other method installs it system-wide. It just depends if you want to use a local install, or install it in your system with root priviledges.
Generally, I don’t like manually compiling code and installing it system-wide because it’s hard to update. Instead, I create local workspaces, and make use of -DCMAKE_PREFIX_PATH to point to the other repos installs if doing it manually, or use a tool such as colcon when there are lots of packages.
As seen here local plotjuggler workspace and its cmake file are found but, plotjugglerTargets.cmake is not. That is the main issue. I checked and this file is indeed not present anyware in the workspace. I am not sure if that is a plugin or a plotjuggler issue in general.
