Hi !
Mission planner is for windows only … So you need to use Apmplanner2 or Qgroundcontrol on ubuntu !
(little tips, on ubuntu 64bits architecture is call amd64, so it is not restrict to amd processors, it is for all 64bit system (x64 on windows)
It’s an Intel Atom 64Bit, The binary I linked to is the correct one. If it doesn’t work, building the code from the source code is not that difficult on linux
“dpkg: error processing archive apm_planner_2.0.24_xenial64.deb (–install):
package architecture (amd64) does not match system (i386)
Errors were encountered while processing:
apm_planner_2.0.24_xenial64.deb”
Could you type : uname -i in a terminal and give us the output ?
I suspect that you install 32bits ubuntu … So you need 32bits binary…
The better should be that you reinstall 64bits version (welcome to linux ^^)
it was reporting as i686 (bah).
Reinstalled to x64 and got it to install, however on 1024*600 screen the app is essentially unusable.
Need a netbook with bigger res screen…
