Plane simulation in Gazebo
Hello all,
I am trying to simulate px4 plane model on gazebo.
I changed sdf and config files as follows;
https://drive.google.com/drive/folders/1C-oMVY6K27NFVNDIDysBXTJjcJM7pD0H?usp=sharing
my world file as follows:
https://drive.google.com/file/d/1MCdzG7LlH8wvxTYh3wHOLKQ1ZlNgIJtM/view?usp=sharing
Frst, I added this part to /ardupilot/Tools/autotest/pysim/vehicleinfo.py
“gazebo-mert”: {
“waf_target”: “bin/arduplane” ,
“default_params_filename”: “default_params/plane.parm”,
Then I start the simulation with this command ;
../Tools/autotest/sim_vehicle.py --no-mavproxy -f gazebo-mert -I 0
Before that I started the gazebo world with this command;
gazebo --verbose titra.world
Gazebo simulation sees the ardupilot plugin but I see not normal movements in the rudder and flaps.
I assign mission from the ground station where I connected the SITL.
The plane does not move when I put it in auto mode and arm it.
I don’t know where I made a mistake. Most likely there is an error in sdf files or is there something i’m missing.
Thank you for your help
@snuffytruffle @SwiftGust
