Plane on bench no disarm
Hi.
I try to commission my little AR Wing with an Omnibus F4 pro flight controller. Currently I have no RC connected to it.
When I power on the system, it directly arms and I can not disam it. When I do I get an error and on the console, I find the following:
INFO MissionPlanner.MAVLinkInterface - doCommand cmd COMPONENT_ARM_DISARM 0 0 0 0 0 0 0
INFO MissionPlanner.MAVLinkInterface - set giveComport Base Thread current False new True
INFO MissionPlanner.MAVLinkInterface - doCommand cmd resp COMPONENT_ARM_DISARM - FAILED
INFO MissionPlanner.MAVLinkInterface - set giveComport Thread Pool Worker current True new False
CustomMessageBox.Show
CustomMessageBox thread calling Base Thread
CustomMessageBox thread running Base Thread
bps 958 loss 105 left 128 mem 109,173828125 mav2 True sign False mav1 0 mav2 27 signed 0
HUD 3 hz drawtime 1 gl True
INFO MissionPlanner.MAVLinkInterface - doCommand cmd COMPONENT_ARM_DISARM 0 21196 0 0 0 0 0
Any Ideas, why I can not disarm it?
Oliver
On the little console in mission planner, I see:
3.01.2022 18:38:35 : IMU0: fast sampling enabled 8.0kHz/1.0kHz
03.01.2022 18:38:35 : RCOut: PWM:1-8
03.01.2022 18:38:35 : omnibusf4pro 002B002F 314E5011 20363057
03.01.2022 18:38:35 : ChibiOS: 93e6e03d
03.01.2022 18:38:35 : ArduPlane V4.2.0dev (c34301d9)
03.01.2022 18:38:35 : IMU0: fast sampling enabled 8.0kHz/1.0kHz
03.01.2022 18:38:34 : IMU0: fast sampling enabled 8.0kHz/1.0kHz
03.01.2022 18:38:34 : RCOut: PWM:1-8
03.01.2022 18:38:34 : omnibusf4pro 002B002F 314E5011 20363057
03.01.2022 18:38:34 : ChibiOS: 93e6e03d
03.01.2022 18:38:34 : ArduPlane V4.2.0dev (c34301d9)
03.01.2022 18:38:32 : Failsafe. Long event off: reason=5
Fixed it … Did a parameter reset :wink:
