Vibration on the second accelerometer is much stronger then on second.
Can this vibration cause uncommanded altitude drift?
Where i can see which accelerometer commanded “rise up”?
set accel filtering to 10hz. This settings apply to all accelerometers?
last flight 2017-06-08 20-23-20.bin (795.2 KB)
i not have altitude rise in this flight, but strange
PI - Index showing which instance of EKF2 has been selected for flight control
But my logs have blank graph
The vibe levels in your last log look totally fine. All below 20m/s/s which is within tolerances (less than 30m/s/s is “acceptable”, 30~60m/s/s is the “grey zone”, above 60m/s/s is definitely bad). You shouldn’t see altitude hold problems at this level.
There are just 3 clipping events which is also nothing to worry about. Maybe it got a momentary whack as it hit the ground or something but in any case, 3 is nothing to worry about. 300, that’s trouble but 3… no problem I think.
I must admit I rarely look at the EKF/NKF messages. I only dig into them if something else looks odd in the main vehicle logging. We’ve done some updating of the EKF description and I think @priseborough plans to update the EKF wiki pages more. … perhaps we can add some descriptions of those log messages.
