Pixracer Pro T motor F55A Pro II 4in1 ESC
Hi I am working about a race drone. I want to use T motor F55A’s battery monitor. I checked F55A specs but ı can not find anything about Vbat and current tolerance. I found pixracer pro tolerance values. You can check it pixracer pro and 4in1 ESC Values from below. Btw ı am regulating +10V ESC BEC to 5,3V for pixracer. And I can’t use Mrobotics power bricks because amp values aren’t enough for my drone. Is support pixracer to T motor F55A Pro II 4in1 ESC. Thx
Sure, why wouldn’t it be compatible? 217A max input with the scale factor from that FC and you will need a voltage divider for Vbat as that’s a 3.3V input also. I like Pixracer’s but why use one on a racer?
is voltage divider not included in ESC
I want to use pixracer pro in autonomous racing competition
Can ı use these resistors for the voltage divider
Voltage divider
Do ı have to supply both vcc pins on pixracer pro
Sure, that will work. Standard values would be a 10k and 1.8k.
Only 1 Voltage input pin is required.
Any supported Flight Controller will do autonomous flight. One with direct battery input may be easier to impliement. No BEC required, power right from Vbat on the 4in1.
thanks for all your answers.
Sorry ı have one more question. Can ı use BLHELİ Configurator on pixracer?
Passthru should work yes. Set SERVO_BLH_AUTO to 1
