I have a PixRacer that I intend to mount using a 5mm thick KOSHO gel pad.
Noting for the FULL sized PixHawk, the recommended mount is to have 4 small squares of foam near each corner of the FC unit. My FC unit is much smaller…and I was planning on the gel pad, not foam. Hoping to hear from others who have been down this road.
Should I try to duplicate that mounting concept, using 4 independent squares of the gel pad to mount the PixRacer? Note the size of the PixRacer is ~ 40mm x 40mm and each of the 4 mount pads would be about 1.5 cm. The alternative is to use one large slab.
I have “lead tape” that can be epoxy-ed to the PixRacer case bottom to give it 40g or more “mass”. Granted, I could mount without the lead and experiment…but was wondering if others have been down this road. Do a vibration test first?
How critical is it that I cover the internal barometer with open cell black foam to block light?
Thanks to all.
