Hi Guys,
Today I tried Copter 3.4 RC2 using Q Ground Control 3.0.0
Is there a way to configure the Voltage and Current monitor using the ACSP5 power module?
I tried all the Analog Inputs and it is not working.
Thanks a lot,
regards,
pturcotte
Hi Guys,
Thanks a lot,
regards,
pturcotte
That’s working for me w/ 3.4 rc2, so probably a configuration issue.
Have you enabled the power module?
http://ardupilot.org/copter/docs/common-power-module-configuration-in-mission-planner.html#common-power-module-configuration-in-mission-planner
