I’m trying to test RTK modules. I set the environment that pixhawk2 cube black with ardupilot connect here+ rtk module. Is it correct below picture?
If I want to use NTRIP features, that connection is correct? Another interface connect was needed?
yes, it is correct. It will work
Thank you~!
I connect pixhawk2 with here +
And, gps/rtk injection was checked in mission planner.
After, I can see “3D fix” → “rtk float”
But, It is not occur “rtk float” → “rtk fix”
why?? I don’t know… More work was needed?
