I have just purchased the Here+RTK for US$600 and can’t get the Rover to establish RTK Lock.
The base station set to 2m accuracy acquires position relatively fast but getting the rover to change from 3D Fix / 3 dgps to rtf Float or Fix is impossible.
I have gone to a flat hill nearby with zero obstruction for 180 degrees in all directions and zip - still no rtf lock.
Anybody have similar experience or found a way around this - or even if you don’t have any problems using the same gear, please help.
Nathan,
I have not read any documentation regarding GPS_INJECT_TO - but will certainly try next time I fire it up.
As far as serial protocol goes - I’m getting Mavlink so I’m sure thats all fine.
