ok thanks.
Well since this setup is just a test platform, I will not go for so many flight hours.
But I will make sure to use cyclic servos for a proper setup in the future.
with your suggestion, the servo moves fine! no burning so far
ok thanks.
Iβm trying to follow the instructions in this thread but I still not get it to work.
Iβve tried to follow the instruction here as well and still have problem.
Iβm using the following HW:
Iβve changed the following parameters:
Param Original Value --> Change to
H_FLYBAR_MODE 0 -->1
H_SW_TYPE 0β>1
ATC_RAT_PIT_VFF 0.15β>0.35
ATC_RAT_RLL_VFF 0.15β>0.35
ATC_RAT_YAW_VFF 0.09β>0.35
H_SW_TYPE 3β>1
ATC_RAT_PIT_D 0.0008β>0
ATC_RAT_PIT_I 0.35β>0
ATC_RAT_PIT_P 0.04β>0
ATC_RAT_RLL_D 0.0005β>0
ATC_RAT_RLL_I 0.32β>0
ATC_RAT_RLL_P 0.035β>0
ATC_RAT_YAW_I 0.3β>0
ATC_RAT_YAW_P 0.22β>0
ATC_RAT_YAW_D 0.003β>0
BRD_SBUS_OUT 0β>1
H_TAIL_TYPE |0β>1
Before connecting the Pixhawk, when I moved the Heli (roll & pitch) the FBL system by default is trying to stabilized the Heli so after connecting the Pixhawk and I move the Pixhawk in my hand the swash plate moved as well which means the Pixhawk trying to stabilize the Heli as well so I donβt really know how to check if the setup is correct.
Another thing is when Iβm moving the roll pitch stick, the servos are moving very slow (Stabilized FM) and not as fast as they were connected directly to the FBL system.
In addition, while looking at the Vbar GUI, when moving the Ail stick, the Ele moves as well, and when moving the Rus stick the Ail & Ele are reacting as well (Not the entire movement)
IβI appreciate some help here.
Thank you very much
Rotem
