Extremely sorry for the delay,
when using the power monitor the autopilot is restarting repeatedly. its again disconnecting by itself.
Sorry, I can’t immediately troubleshoot it for you, based on my experience. You can try the following:
- After removing the SD card, start it again. Check if the SD card is damaged.
- If you have other boards, please try to replace it with a good baseboard.
If none of the above methods can solve the problem, please contact your supplier and they will help you solve the problem.
we tried the cubev5+ in q ground control software and the autopilot is connected but the communication between the autopilot and QGC is lost
error msg in QGC, vehicle 1 did not respond to request for parameters. This will cause QGC to be unable to display its full user interface.
