It’s definitely from the flight controller, as it will make the sound when plugged into USB where the ESC and such are not able to make any sounds.
Interestingly… I was not able to get the boat to navigate using 3.2.1. I downgrading to 3.1.x and it works fine… sound is either the same or no sound though. It’s running a Pixhawk 2.4.6 clone. It could be I just don’t know the new tuning params for 3.2.1 but it was bad - in auto it goes backwards and steering just does circles - tried channel reversing, etc. I will try it with another Pixhawk but am wondering if there may be a hardware problem at play.
A number of things have changed between 3.1 and 3.2.1 but it should be possible to get the vehicle navigating at least as well with 3.2.1. I suspect the vehicle just needs to be re-tuned. Here’s a guide but in short, the most important parameter is the ATC_STR_RAT_FF.
Indeed, I finally took the time to hit the lake and get the tuning worked out on the new firmware. It was the ATC_STR_RAT_FF param. Boat is tracking very well now. Loving the improvements!
It’s going to continue to get better I think. We’ve still got a few features like rally points and follow to port over from copter and then there is a slightly more difficult navigation improvement we hope will allow the “ackermann” steering vehicles (i.e. separate steering and throttle controls) make more consistently tighter corners at higher speeds.
