I have been scouring the net for solutions/information on using the pixhawk for logic switching or as it is commonly reffered to on the wiki, “Relay Switch”. I just want to trigger the pixhawk with my transmitter and have the pixhawk output a 1 0r a 0. 3.3 volts or 5 volts.
My solution so far:
-First, set the BRD_PWM_COUNT=0. (I want to use RC9 or Aux 1, but I still set all AUX IO’s to be relays)
-Second, define the “First Relay” or RELAY_PIN= 50. (this is pixhwk AUXOUT1)
-Third and this is where I am confused; I define SERVO9_FUNCTION = 1, 10, 59 or anything that makes sense.
This is really the last step that feels correct to me. However, there is no output when I begin to trigger my Transmitter switch. From the flight data page Channel 9 input ppm values show min=1000 and max= 2000. Is this possible with the Pixhawk flight controllors or am I chasing my own tail? Is this only able to be done durin auto missions? Any help would be greatly appreciated.
Thank you Mike for your input. You got me thinking about what I am doing wrong. I have read your solution in another discussion. Looks like my mistake was the firmware.
I am using plane firmware. The relay options are only for copter firmware from what I can tell. Can anyone confirm this?
