you forgot to share the log with those with the link, but while admitting to being experienced at ignoring warnings about voltage & compass … is a crash now and then really undesired by you ?
The voltage input of pixhawk is 4.1v to 5,7V - (ideally 5v)
you are feeding it 5,6v , the highest record for your flight is 5.656v , there are some peaks…
At anything above 5v7 , the internal power management will disconnect power (to protect the finer linear regulation) - From what I see, You have way too high voltage, and most likely do not provide redundant power to the Pixhawk (or provide equally high , or higher backup power)
