So I am trying to set up my hexacopter with my Pixhawk. Everything is set up EXCEPT the sensor calibration. I have tried to complete it multiple times but this is what shows up: (look at attached file) I complete all 3 requests and then it tells me “Choose one of the positions and hold it there”(or something along those lines). I do it and it says “calibration failed” and then the guys says a lot of stuff. In the end it says the calibration failed because there was no movement. What should I do?
@traw1234,
Are you using the Stable version of QGC or the daily build?
You might try the daily build if you are using the Stable build.
Regards,
TCIII AVD
