Does anyone know the exact wiring of the cable which powers the pixhawk from the power module? All the pins from the jst-gh connector recently came out after a crash. And these connectors are costly and not easy to find where I live.
If those pulled out of the housing, you will likely need to get a new housing at least, or a whole new cable.
I was able to find one here and I’ve verified with a multimeter that the wires are in a 1:1 relationship with the connector on the flight controller end.
Ok, that helps! Thank you so much!
