Hi everybody.
Several months building a large quad with pixhawk px4 fmuv2 installed, and long range video transmission, with a gimbal, and powered by a large 22volts 12000mah battery. The whole weight is 4kgs, and the quad flew for continuous 35 minutes. I was very happy about the long flight time and its good stability. Until last week, and just the second flight when I was trying video recording above a lake, and after 5 minutes flight, the quad began to wobble crazily, and I couldn’t control it before it was falling into the lake and sunk. After five hours, I was able to extract it from 3 meters under water ,using a water bike and following last GPS position in QgroundControl.
After reviewing the log, and connections, I concluded that the cause might be a disconnected wire from the power board which touched the board and caused it to burn, although the ESCs were directly connected to the battery and the pixhawk directly to the power module.
I disassembled all the parts,clean, brush,dry… and I was happy I could recover all of them except for the pixhawk.
After first connect to Pc via usb port, it was powered normally, all leds and main light were functionning OK. But I couldn’t power it from battery. Another thing was that I could install the px4 firmware on it but not the arducopter and the main led light never lit. And after a stupid try of installing px4io bootloader from sd card, the pixhawk was no longer seen from MP or Qgroundcontrol, I tried the python loader , it gave a message “waiting for the bootloader” although I tried to hold switch while powering the pixhawk.
Note: the leds status when connected to pc in normal mode:
IO POWER AND FMU POWER:ON
IO B/E: ON
IO Act: blinking
When in boot mode
IO B/E:blinking
IO Act: OFF
Pictures Before and after crash and log file are attached**
Uploading: 20200212_215731.jpg… Uploading: 20200317_154851.jpg… Uploading: 20200317_175513.jpg… Uploading: 20200317_175517.jpg… https://drive.google.com/open?id=1lMIJXHXnNArYOJhicrXHQeZLS-_y1VWJ
Any help to recover my pixhawk back and also resolving powering problem from battery will be really appreciated.
Thx in advance
