Full_Param_List_for_Test.param (10.4 KB)
I just attached the file so you should be able to open it…let me know if you have any issues with that.
What firmware is this? You have posted in Plane 3.8, is that what it is?
Well I just want to have the pixhawk on its own for the test…not configured as a plane, copter, rover, or anything else. So I’m not sure what to select for the “Install Firmware”, and I’m not sure why it is set as Plane 3.8. I didn’t do anything myself to set it in that mode.
Also, when I go to the “install Firmware” page I don’t actually see a Plane 3.8 option. All of the options are “4.0.(something)” versions…this might be relevant?
On it’s own? It needs a vehicle target. So if it doesn’t matter select the Copter 4.0.7 Official and flash that. Then because you have a bunch of junk in the current firmware go to the Full Parameter List and hit the Reset To Default button. I would reformat an Sd card and use that.
You should have created a new post rather than post in this old thread that is for Plane 3.8.
Is this problem solved yet? I have flashed Pixhawk 1.0 with the stable release 4.x.x
Tried resetting the default parameters, changing Log_Backend_Type from 1 to 2 to 3, to 5 to 7.
I tried Bitmask both default and 65535, with no success.
I cleared the previous log multiple times and it keep showing up. Before I gut the Pixhawk out of the quadcopter to manually access the SD card, are there any other parameters I should try out?
