I have a pixhawk setup in an airplane and would like to set waypoints and fly missions. I have mission planner installed on a laptop, but at the field I do not have an internet connection, thus I can’t get a satellite view the flying field. I have an iPhone 6 and can download Mav Pilot which I believe would allow me to plan missions, but what do I need to add to the pixhawk in order to establish either a wifi or bluetooth connection to the iPhone. I could be wrong, but I don’t believe the pixhawk has built-in wifi or bluetooth. Mission planning is new to me and I could use some help in getting things setup.
Or, if your iPhone is running IOS 9.x then you can create a wifi hot spot and connect your laptop to your iPhone and get a internet connection through that hot spot.
I’m going to first try planning a mission at home for our field 10 miles away and then save, and reload once I get to the field. I’ll see how that goes first.
After that I may try the hotspot with my iPhone. However, does the pixhawk have a ‘built-in wifi’ or do I need to buy something to plug into the pixhawk. If I need to buy something, what would you recommend and where would I get it.
I use one of the standard radio modules, one on the model and the other connected to my phone, as my phone does not support anything connected to its USB port I have connected a Bluetooth module to the radio module and power that by a single cell Lipo then connect the phone to it via Bluetooth
