Hi Folks,
I purchased a Pix hawk mini and done testing, everything was good. All of sudden I encountered powering issue with the receiver. I found there is an issue with the voltage regulator in the Pixhawk mini, can someone assist me??
Hi Folks,
I have simply used an external 5v regulator in cases where the one on the FC died. You may have to cut through some traces on the PCB to completely disable the onboard regulator.
I get them at Pololu, but there are plenty of options.
