Background:
I have been flying my fixed wing with Pixhawk Mini using QGC, but the mission mode is hit and miss. So I decided to flash it with Arduplane FW, and now I am using Mission Planner.
Problems:
- In the “Servo Output” no response from the throttle can be seen in the update bar; however, I can see it moving in the “Radio Calibration” screen. I have done calibration multiple times with same results.
- In the Servo-Output screen if I check mark reverse box motor starts to spin full speed.
- Arming, does not require holding the rudder stick to the right for few seconds after safety switch is engaged?
Setup:
Channel 1 and 2 are setup as elevons.
Channel 3 is servo.
Channel 4 Rudder (But the plane has no rudder)
Channel 8 flight modes.
In the QGC, channel 4, was throttle and I had the ESC wire hooked into pin-out #4.
Appreciate some help.
Thanks,
Riz
