Not much of a forum poster but getting frustrated.
Have a Pixhawk on a Hex and have had quite a time getting things sorted out. I have been happy with the results when things are working though.
I had a problem with modes, they appeared to be working in mission planner but only stab would work while flying, the others only sent it falling to the ground. But in stab I had it flying good. I switched the stab to Loiter in MP and it was out of control, It would wobble a couple times and then roll 45+ and take off and input controls had little effect, other modes only sent it falling toward the ground. Very ugly crash resulted.
Not sure what I did but the modes are working now, stab and alt hold work very good but in Loiter it still loses control rolls and takes off, Tx controls have minimal effect, have to switch modes to save it.
Another issue, the Tx pwm readings when shut off (1160) are higher than the low throttle pwm (1102). I have failsafe set at 1088. I will not have FS if out of range. Not sure what to do next.
I have another controller here but I want this Pixhawk to work. I am getting there but ran out of google search ideas.
I find the instructions a bit lacking when you have a problem. When I did not have the modes it was probably something like not saving correctly etc. but there is no confirmation??
Thanks!
