Log attached. Starts with compass calibration then 20 mins flight and several attempts to engage loiter. If it is too long I’ll make a short flight with just the issues.
[attachment=0]Log.zip[/attachment]
Yup, she flies really well in Stabilize and Alt Hold. I auto-tuned. Was still a little fidgety so I brought down the rate P,I & D 10%
Just tested now and success!
Assuming the Pixhawk and Ublox was working, (Ublox was 10cm or so above everything on an aluminium stalk from the start) it had to be something causing greater than normal mag field. So I checked everything and re-run all the cables to the lowest position possible plus one of the ESC’s had two bullet connectors not in all the way. They connected well but the copper was little bit exposed. Fixed that, re-ran live calibration and Loiter works perfectly albeit a little fidgety.
Should I tune down the Loiter PIDs some?
Then I went through the compassmot motions - prop switch, secure chopper, throttle up etc - without actually running compassmot. There is still a slight variation in heading with the throttle at 75% and the aircraft held down in place.
